cjaya.1
I am getting a error when I enable the I2C and try to use with HAL library for I2C on the STM32cube IDE. I am getting this error message: "fatal error:stm32f4xx_hal_i2c.h: No such file or directory" .
Hello @cjaya.2kody​,
You'd want to review the defines, and paths used.
Probably, you are missing an include file. So, make sure that the Include Paths are set up coherently.
Imen
