jerry pang
How to use STM32F40X CCM SRAM in STM32CubeIDE?
I know how to use ccm in keil, but now i have a project used CubeIDE, i dont know How to use STM32F40X CCM SRAM in STM32CubeIDE? thank you for your answer and help?
After Forever
Senior III
September 19, 2019
STM32CubeIDE uses the GCC toolchain, so most likely you do it manually by modifying the linker file and setting correct attributes for the variables (and/or functions) which you want to end up in CCM SRAM.
OpenSTM32 - Using CCM Memory
AN4296
Also note, there are different types of CCM SRAM, for example, you can't run code on STM32F405/7 CCM SRAM, it's not connected to I-BUS.
jerry pang
thanks for you help ,but i dont find the way to use it. do you have any link or suggestion to real use it.
September 20, 2019
Did you even review the App Note cited above?
Add the sections to your .LD Linker Script
Direct content with attributes.
Initialize the space in startup.s
Perhaps gain a better understanding of your compiler and linker
