How to revert a subfolder back to general project properties
I changed the properties of a subfolder (causing it to get a wrench icon), and now I want to undo that but I cannot find a way. There is a restore defaults button which i tried but the wrench button is still there do i am guessing this means the folder properties will still not be in sync with the general project ones. Any other clean solutions ? If not I hope editing the the project file directly (which is apparently a bit of an undocumented mess) will do the trick ?
