VNava.1
May 26, 2021 3:10 PM UTC
How to recreate a project made for Keil essential using STM32CUBEIDE instead
I ask this question because, trying to recreate an application on STM32 CUBE IDE, which was built with KEIL ESSENTIAL, I noticed two different behaviors flashing the binary generated by Keil with the binary generated by STM32CUBE IDE. In particular, the Keil binary worked correctly (since it was the IDE originally used), while the binary generated by CUBE IDE did not. Have you ever had similar problems?
