The CubeIDE debugger relies on the GDB load command to dispatch task of loading binaries to the currently used GDB-server.
In this way the debugger does not really have to know/care much about which target is connected. We trust that the GDB-server has the awareness. And in that
This gives us a clean interface between CubeIDE and the debugger back-end and the benefit of less maintenance and code duplication.
The down-side is that the load command of GDB does not support loading srec-files.
Still what you want to do can be achieved relying on other features in the IDE. My advice would be to:
- Setup an external tools configuration, where you invoke JlinkCommander to carry out the srec load.
- Then make sure that the debug configuration points to use the elf-file, but has unchecked the download check-box or we will overwrite the srec...
- You can then setup a Launch group which will allow you to chain the external tools config as a first step. Once finished the Debug config will be launched. You should probably also disable auto-build in the debug config which does not make sense to have between the external tools config and the debug config.
This could work depending on what your "elf-->srec" script does...
Could this work for you?
