Kunal_Atom
How to integrate Scons build system in STM32CubeIDE?
I tried to do it the same way it is for Eclipse but it is not detecting the SConstruct or taking the Python Library
Pavel A.
April 19, 2020
CubeIDE is Eclipse. How it works in your Eclipse? Does your scons run on Jython included in Eclipse, or on external CPython?
-- pa
Kunal_Atom
Hi Pavel, thanks for responding.
  • My scons runs on normal Python using PyDev plugin in eclipse.
  • I tried the same set of settings I did in eclipse but working there in eclipse.
Pavel A.
April 21, 2020
Then probably it can work as "makefile" type project. Instead of "make" specify your script as the build command.
-- pa
