PMuda.1
March 18, 2021
how to flash merged hex file in stm32cubeide?
EJOHA
Hi PMuda.1
To flash hex files I recommend you to use the STM32CubeProgrammer tool. In STM32CubeIDE only the command line version of the tool is included. The complete STM32CubeProgrammer tool also contains a GUI version. It can be downloaded from the ST web site.
March 18, 2021
Perhaps you can write a script, the format is simple and well documented.
Generally you'd concatenate the two files, losing the end record on the first.
