bully
Senior
September 18, 2022
How to deal properly with weak interrupt function and override in assembler ?
I have problems with implementation of weak default function and override with real function in assembler.
I have this in startup.s (usually all functions are defined like this):
.weak SysTick_Handler
.thumb_set SysTick_Handler,Default_Handler
and then have defined function in main.s:
.global SysTick_Handler
.type SysTick_Handler, %function
SysTick_Handler:
 push {r3, r4, r5, r6, lr}
if I comment those two lines in startup,s, then proper SysTick_Handler gets triggered, otherwise it ends in Default_Handler. I'm obviously doing something wrong ?
Thanks.
Tesla DeLoreanBest answer
September 18, 2022
 .syntax unified
 .cpu cortex-m7
 .fpu softvfp
 .thumb
 .section .text.SysTick_Handler,"ax",%progbits
SysTick_Handler:
 .size SysTick_Handler, .-SysTick_Handler
September 18, 2022
 .syntax unified
 .cpu cortex-m7
 .fpu softvfp
 .thumb
SysTick_Handler:
bully
bullyAuthor
Senior
October 28, 2022
have tried to replicate your advice, but I still get into Default_Handler.
It doesn't seem to help, I have to comment second line in startup.s.
. Can I check in some output docs what could be wrong ?
// .thumb_set SysTick_Handler,Default_Handler
And I have this in main.s
SysTick_Handler:
// adr	r3,LEDSTAT
// ldr r4,[r3]
// cmp	r4,#0
 add r8,r8,#1
 cmp r8,#500
 blo RET
 mov	r8,#0 // reset ms counter
 cmp r7,#0 // check flag
	beq LOFF
	mov r5, #LEDs_OFF
//	mov r4,#0
// str r4,[r3]
 mov r7,#0
	b CONT
Thanks and regards.
