ckim.2390
How to create ***.map file at build time?
Or, in which file is the build information for the executable file written?
@ckim.2390​ Hi,
Could you specify your toolchain?
ckim.2390
ckim.2390Author
sorry.
I don't know in detail.
I initially set the map file option in the "./cmake/st-project.cmake" file.
I added it and it worked.
But in the first line of "st-project.cmake" file
"# THIS FILE IS AUTOMATICALLY GENERATED. DO NOT EDIT."
is written.
If so, where should I add additional build options or include paths between "CMakeLists.txt" and "gcc-arm-none-eabi.cmake"?
