jin1
Oct 19, 2026 10:29 PM UTC
How to create a project using fp-sns-stbox1
I am a newbie with the concept of function pack.
I would like to  create an from scratch starting from the fp-sns-stbox1. I would like to start by  installing /importing fp-sns-stbox1 and use it’s source ( such as drivers, bsp etc..) to build ny application.
All the documents that I see describes the features of the fp, but no guide on how to install/import so that I can modify the code to
implement my application. Tried to  import then compile, which  gives me error ‘no make file’ etc..
What is the best way to accomplish my objective?
Andrew Neil
Oct 20, 2026 9:20 AM UTC
It’s a set of example projects - so you use the ready-made project which seems closest to your use case, and adapt from there.
Apart from that, you can just take the source code and add it a project of your own creation - just as you’d add any other software that you’d created, or any software from a 3rd party.
jin1
jin1Author
Oct 20, 2026 4:01 PM UTC
I am hoping to do just that. Thanks for the help
