RafaelJoseph
How to add preprocessor symbol in STM32Cube IDE
#error "Define according the used Cortex core ARM_MATH_CM7, ARM_MATH_CM4, ARM_MATH_CM3, ARM_MATH_CM0PLUS or ARM_MATH_CM0"
Based from this Topic https://community.st.com/s/question/0D50X00009XkXPtSAN/need-help-in-dsp-library-for-keil-
The problem is solve by adding the preprocess symbol in Keil Uvision, What is the equivalent of this in STM32CubeIDE?
Yuk117
Yuk117Best answer
To add preprocessor symbol is...
  • Right click on your project -> click Properties.
  • Select C/C++ Build -> Settings -> Tool Settings tab -> MCU GCC Compiler -> Preprocessor.
  • Click Add Button and input your symbol.
Yuk117
Yuk117Best answer
scottSD
Senior III
January 31, 2022
What is the best way to use these symbols in your code? I am having trouble with compiling my code when referencing symbols defined this way.
