SMoor.6
How do I get GDB debug output to a file?
I'm debugging a problem on the target. The data I want to examine is in an array and can be easily seen in the Debugger console using "print output_data". I'd like this in a file to facilitate further host processing. When using gdb standalone I can do this with "set logging file my_log.txt" but this doesn't appear to work with GDB within STM32CubeIDE. I'm having to resort to copy and paste which works but is a bit tedious.
KnarfB
KnarfBBest answer
add a command
set logging on
to make logging to the file active.
hth
KnarfB
KnarfB
KnarfBBest answer
add a command
set logging on
hth
KnarfB
SMoor.6
SMoor.6Author
Thank you. That works. I'd assumed that setting the log file name turned logging on.
Just to be clear for anyone else...
set logging on
set logging off
