How do code for controlling a Stepper Motors with IHM02A1 in STMCUDE IDE
How to use X-CUBE-SPN2 in STM32CubeIDE. It creates errors while adding X-CUBE-SPN2 in STM32CubeIDE. I have done every solution given. But they are not giving the result. I would be grateful if anyone could come up with a complete solution
Hello @PavanKaruchola ,
First let me thank you for posting.
It is the same topic that has been discussed here.
I suggest also that you consult this User Manual.
Thanks.
Mahmoud.
Thanks.
Mahmoud.
Thank you for your response. I knew the process of adding expansion software but I didn't find the X-CUDE-SPN2. When I try to install it manually at the embedded software manager it gives me an error. Could you please consider the above points and provide me proper steps?
Hello @PavanKaruchola,
I suggest please that you provide a screenshot of the errors which you have encountered.
And I want to know the board that you are using.
Thanks.
Mahmoud.
The issue is solved, sir. Thanks for the solution
