qcho.1
How can I represent multiplicative inverse in GF(2^8)?
Hi, I'm here to seek help.
I would like to represent multiplicative inverse in GF(2^8), using textLCD in mCube cortex m4 with stm32407vg.
I'll use functions, unsinged char xtimes(); and unsigned char inv(unsigned char a);
And also, I want to represent result value of inv() seems like [inv : (value)] on textLCD.
Is there the way to input value using my mCube cortext m4, and represent result value?
December 1, 2022
Could you use sprintf() and sscanf() ?
What's your input device?
How is the Galois Field stuff related to your ability to display things on the screen? ​
qcho.1
qcho.1Author
I changed the way I had it in mind: using 2 buttons on the keypad to increment/decrement each value and display the inverse directly on the textLCD or 7-seg.
1) How can the result be displayed if I use sprintf()?
2) The input/output device is mCube micro processor.
3) The multiplicative inverse of GF(2^8) should be displayed on the device.
December 1, 2022
Presumably sprintf() could create a message string that you subsequent paint on the screen in the format you want.
What is an "mCube micro processor", you mean mBed or or CubeMX ?
Provide a web link to what you're talking about.
