SMac
How can i download project from STM32CubeIDE to micro controller to make it work without USB connection with PC, only with power supply?
  • October 9, 2019
  • 8 replies
  • 2302 views
Can't find any drop down menu or other pointer to this functionality in STM32CubeIDE v. 1.0.2. My stm32 device - STM32 F429ZI - Nucleo. Please, help me to solve the problem?
Do you want to flash the chip without a USB connection?
Or do you want your program to run after flashing, and after disconnecting the USB cable?
SMac
SMacAuthor
I want my program (after building in STM32CubeIde v. 1.0.2) to run AFTER disconnecting the USB cable.
Once your program is in flash, you can supply power some other way and your program will run once it receives power. For example, using an external power supply.
SMac
SMacAuthor
Do you mean that since i have run once my program in debug mode on device, it apears in flash and after that the one thing i need to do is to connect it to external power supply and disconnect from USB?
Yes, that is typically what happens. Running a program will download it to the flash as the first step.
SMac
SMacAuthor
Unfortunately, after i disconnect USB and leave only power supply, my stm device turns off :(
Time to break out the multimeter.
Does it still have power? Is the NRST pin being held low by something?
