BViet.1
How can I disable the login shortcut?
I have a simple question. I'm using STM32CubeIDE v1.14.0 on MacOS and I want to use Doxygen for the source code documentation. The problem is that the shortcut for Login to myST is the same as the "@" shortcut. So it is not possible to write the "@", because every time the login popup comes up.
Does anybody knows how to disable the login shortcut (OPTION+L)?
    BViet.1
    BViet.1Author
    I can see that it's a known issue, because the shortcut is hard coded and cannot be disabled or changed at the moment.
