JBonn
Hot to do a discovery using Device authentiction
Did numerous builds using CubeIDE (10,000 lines of code). this error started coming up. "reason was unknown target"
Got the following message:
Make -j4 all  DriversSTM32L4xx_HAL_Driver/subdir.mk.91:  *** unable to generate command line.  stop.  "make  -j4 all"   terminated with exit code 2. Build might be incomplete.    Build failed. 1 error 0 warnings
Cannot clear the problem. In IDE Debug configurations,  Project, Tool settings,  MCU settings ---There is nothing in the MCU and board (Custom board) slots.
    Pavel A.
    Do you have a backup? Version control?
