MTahe.3
December 5, 2022
Hi, I installed STM32IDE latest Windows version on my laptop and I am getting the following error: Cannot run program "make": Launching failed Error: Program "make" not found in PATH But on my desktop, I don't see any problem. Any advice, please?
Show a full screenshot of the issue. How did you generate the project this occurs in? Likely the project is not properly imported or otherwise misconfigured.
If you generate a new STM32 project, does it compile?
S.Ma
Principal
December 7, 2022
Make sure to run installer as admin. Test with a simple nucleo board base program
