H747i-DISCO programming/ creating binary
How would I be able to create a binary for this project or run it through CubeIDE?
For some context I have taken this project from the FP-AI-VISION1_V3.1.0 pack, made some modifications, and would like to flash my H747i board with it. I can build the CM4 and CM7 files but when it comes to running the entire project or creating a binary for it I am at a loss.
Thank you!
mƎALLEm
mƎALLEmBest answer
Not sure what the problem is, but the there is no hex or bin generated after the compilation but you can use .elf files located under :
STM32CubeIDE\CM4\Debug\  -> for CM4
STM32CubeIDE\CM7\Debug\  -> for CM7
To load the two binaries for both CM4 and CM7 with STM32CubeProgrammer tool.
Otherwise could you please detail what you did exactly at programming step?
mƎALLEm
mƎALLEmBest answer
tw1Author
It was an issue regarding file path naming being too long.
