NickO
GitHub Copilot seems broken (Cube IDE 1.19)
Running ST Cube IDE 1.19 on Windows 11, co-pilot autocompletions seem to be causing an issue. I see the suggestion, then a dialog pops up saying the following:
An internal error occurred during: "Generating completion...".
Invalid thread access
I look at the error log as I see the following:
Failed to parse wmic output
Exception Stack Trace:
org.xml.sax.SAXParseException; lineNumber: 1; columnNumber: 1; Premature end of file.
at java.xml/com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(DOMParser.java:262)
at java.xml/com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(DocumentBuilderImpl.java:342)
at com.st.stm32cube.ide.mpu.remote.serial.internal.SerialPortProviderWindows.run(SerialPortProviderWindows.java:127)
at java.base/java.util.TimerThread.mainLoop(Timer.java:566)
at java.base/java.util.TimerThread.run(Timer.java:516)
Ghofrane GSOURI
Ghofrane GSOURIBest answer
Hello @NickO
Let’s try reinstalling WMIC by following the steps provided in  LINK
Ghofrane GSOURI
Hello @NickO
I'm currently checking this behavior. I will be back to you asap.
THX
Ghofrane
NickO
NickOAuthor
I am using Windows 11 Version 10.0.26200 Build 26200
Ghofrane GSOURI
Hello @NickO
Just to confirm, which version did you use exactly?
NickO
NickOAuthor
Quite possibly (glad it's not just me - I was wondering!). Also, check for an update to the Github Copilot plugin. I had one come in yesterday.
Graduate
I am also being offered to update the IDE to version 2.0.0. Is it worth doing, or is it still buggy?
NickO
NickOAuthor
I'd not seen that. I'm going to try on my own PC first. Did you get GHCP working?
