VKUMA.12
Float variable not working in stm32cube_ide.
Float type variable is not working in stm32cube_ide.
float r = 3.14;
when I debug the value of r it shows 3 and also I cross verify by using if condition.
if(r==3.14)
but condition fails, that means float variable not working in ide.
Please help!
AScha.3
your joking, eh ?
write:->
float r = 3.1415f; // xxxf = float define
and bool compare == never useful working on float !! (or random, depends on compiler etc.)
October 3, 2022
How are you debug/inspecting it?
3.14f would be the preferred usage.
Check printf() of floats is enabled, by default it might use the smaller library.​
LCE
Principal III
October 3, 2022
Check your project settings:
properties -> C/C++ Build -> Settings -> MCU Settings
There you can find settings about floating point hardware / software
and floating point support for printf.
VKUMA.12
VKUMA.12Author
Thanks!
3.14f working fine.
