NOza.1
Float value gives hard fault in STMCubeIDE
I am using a STM32F4/STM32L4 MCU and STMCube IDE (1.3.0) for the development. It gives ma a hard fault when I print float values.
float value = 3.14f;
printf("Value: %f\r\n", value);
I have enable -u _printf_float as mentioned in attached image. Will you please help me to resolve the issue?
So you can use floats, but the hard fault occurs when using printf with floats?
printf uses malloc, might be malloc failing.
Where is your printf sending data?
NOza.1
NOza.1Author
Que: So you can use floats, but the hard fault occurs when using printf with floats?
Ans: Correct.
Que: Where is your printf sending data?
Ans: UART
