FileX initialization error
Hi, All
   I tested eval board of MB1550C with MCU of STM32U575.
   I setup FileX, ThreadX and everything according to the document, but when software initialise it in
  MX_SDMMC1_SD_Init(). Error happened.
  I setup frequency to 48M.
It seems that the SD card are not detected at all.
Thanks in advance.
Victor
    Ghofrane GSOURI
    Hello @Victorheca01
    First let me thank you for posting.
    Could you please provide your IOC so that we can check your configuration and determine what could be the problem?
    Thx
    Ghofrane
    Hi Ghofrane,
        Thank you. Attached please find my IOC file. thanks in advance.
    Victor
    Ghofrane GSOURI
    Hello @Victorheca01
    Thanks for sharing your IOC.
    It has come to my attention that you activated Filex, Thread X, and USBX after using the 'initialize all peripherals with their default mode' option.
    I recommend using the "initialize all peripherals with their default mode" option and then clearing the pinouts (to maintain the correct clock configuration), configuring  the peripherals necessary for your application and ensure that there are no conflicts in your configuration.
    I will be waiting for your feedback.
    Thx
    Ghofrane
