Mar 22, 2024 10:52 AM UTC
Failed to evaluate expression
I have tow arrays one named adcData[] that is adc input buffer and Xbuf[] that is output buffer. Now i am calculating some paramaters... But when i use my debuger and Live variables, i get only adcData[] and Xbuf[] is "Failed to evaluate expression". Arrays are declared same way and everything is configured similarly.
    MihaBest answer
    Nov 7, 2024 3:05 PM UTC
    if you want to see live expresions, you need to uprdate variables slowly. if speed is more than few 10Hz data is not shown.
    MihaAuthor
    Mar 22, 2024 11:00 AM UTC
    Semer CHERNI
    Apr 2, 2024 2:15 PM UTC
    Hello @Miha
    First let me thank you for posting.
    The issue seems to be linked to the syntax of the variable in the "Live expression"
    BR,
    Semer.
    MihaAuthorBest answer
