NBhar.1
Error while debugging.
Hey guys I am facing this issue badly and I am not able to figure out the issue.
Please let me know what could be the problem. I have shared the error below
Error in final launch sequence:
Failed to execute MI command:
target remote localhost:61234
Error message from debugger back end:
Could not read registers; remote failure reply 'E31'
Error mes
Thank you.
Does your code reconfigure SWD pins on GPIOA? Do you enter low power modes?
NBhar.1
NBhar.1Author
Yes to both the questions.
You can't debug if the SWD pins are reassigned elsewhere.
Debugging in low-power mode is possible but generally not enabled by default. Look in the appropriate reference manual for how to enable it, generally within DBGMCU.
