error "no ST Link detected"
hi everyone, idk if this problem was already reported but i didn't find anything that helped me solving my problem.
i'm using the board B-L475EIOT01A and everytime i try to debug in my STM IDE it tells "no ST Link detected".
can someone pls tell me step-by-step how to solve this problem?
can it be that my pc doesn't see the board?
thanks
    You'd need to see the board and an ST-LINK in Device Manager. You'd need the right driver, a suitable data cable, and plug into the correct USB port. Check the board provides an ST-LINK, and not an external SWD/JTAG pod.
    ST-LINK is on-board via connector in North East top edge. Make sure you have a good cable, not a power-only charger cable.
    zanna989Author
    i think everything is working properly, also the cable is the one that my university gave to me.
    i read that the problem could be the firmware version, could it be?
    idk how to do the update
    zanna989Author
    so it's possible that the data cable could be the problem
    actually I went to look at Device Manager and it seems that the board is not seen by the PC
    also how can i check that the board is providing an ST-LINK
    sorry if my questions are trivial but i'm a beginner
    zanna989Author
    ok thanks
