remoter
Error in initializing ST-LINK device. Reason: No device found on target.(Stm32H755)
Recently, I got some projects from my professor and tried to solve that with my Nucleo-H755 Board.
I found that the way How to debug this MCU, Stm32H755 is pretty different with other st mcu, so i followed this video to set the debugging environment.
https://www.youtube.com/watch?v=jI1k6p-fduE
After applying some settings, I checked that my board got a problem.
I couldn't connect to my board anymore(Cubeide- Debugging Mode or Cube programmer connecting) but still can check the voltage of st-link and volume of memory Storage.
I would really appreciate it if you could give me a suggestion to solve this problem.
Thank you.
TDKBest answer
What settings were those? Did you change SMPS/LDO settings? Recovery instructions are here:
https://community.st.com/t5/stm32-mcus/how-to-unbrick-an-stm32h7-after-setting-the-wrong-power-mode/ta-p/49691
If it was something else, you can generally recover by holding BOOT0 high during reset.
TDKBest answer
remoter
remoterAuthor
I just solve the problem after applying your advice. Thank you for your help!
