Error: cannot open jar file c:\Program::
Issue #1: I am using the latest Versions of CubeMX and CubeIce running Windows 10. I have been using the these for several months. In the Past I could double-click the .project file for a project and cubeide would launch and load the project. Now, that doesn't work. I get the message "Error: cannot open jarfile c:\program" in a pop-up box titled "java virtual machine launcher". I have re-installed java jre-1.8.0.281. The project of interest can still be imported into cubeide an modified (except as below).
Note that I updated to the latest version of cubeide after noticing this problem in an earlier version. Did a windows update crate the problem??
Any suggestions??
