FBLBest answer
Hello @Nsg1987,
Thank you for highlighting a frequent topic/question. Here is an example developed by our colleague in which you can test Inter-CPU asynchronous communication. However, I guess we cannot judge if this is the best or easiest way to share data between two cores.
Hope this helps!
Piranha
Principal III
July 23, 2023
Generating a duplicate topics for the same issue is spamming. Why are you spamming?
An you have already received all the details in your previous topic:
https://community.st.com/t5/stm32-mcu-products/memory-sharing-between-m7-and-m4-stm32h745/td-p/573941
FBLBest answer
Hello @Nsg1987,
Hope this helps!
Piranha
Principal III
July 26, 2023
That link was in the topic, which he said he did read, and it was also recently already given to him specifically and the reaction was: "Could you share any other way..." Beginners cannot do everything - one has to learn things.
