Duplicate ADC Initialization Calls in IOC-Generated Function
After updating to STM32CubeIDE Version: 1.16.0 Build: 21983_20240628_1741 (UTC), I've noticed that HAL_ADC_Init is being called twice. This behavior is different from the previous version 1.15, where it was called only once. Although the code still functions correctly, it seems less streamlined than before. Could you please review the attached MX_ADCx_Init.c file for potential issues or necessary adjustments?
STTwo-32
STTwo-32Best answer
Hello @rflamino
I've been able to reproduce this on my side. It does not seem to be a source of problem, but I've reported to the concerned team (under internal ticket number 185621) for review on the coming versions.
Update: this issue has been solved on the STM32CubeMX V6.13.0.
Best Regards.
STTwo-32.
STTwo-32
STTwo-32Best answer
Hello @rflamino
Best Regards.
STTwo-32.
