qua
Disable rebuild on run
Is there a way to stop the project being rebuilt when I run it? I'd prefer to use the last build, rather than building again every time.
I checked the project and build configuration options but couldn't see anything. Thanks.
KnarfB
KnarfBBest answer
in STM32CubeIDE menu bar Window > Preferences search for build and you get a hit in Launching. That's what can be configured. Give it a try.
hth
KnarfB
KnarfB
KnarfBBest answer
hth
KnarfB
qua
quaAuthor
Thanks, that was well hidden.
Pavel A.
June 23, 2022
Also, in every launch config (aka debugger config) you can disable build before debug. This is tedious but usually you review launch configs before first use.
