different Build Configuration for different pinout version
Is it ok to use different build configuations for different pinout version?
As you may have experienced, sometimes pcb version how the pinout. Sometimes another UART or TIMER is used in another pin etc,...
Saket_OmBest answer
Hello @carleslsregner
Yes, it is OK and often the best solution to use different build configurations for different PCB/pinout versions,
In order to give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question. Saket_Om
Saket_OmBest answer
Andrew Neil
Yes, as @Saket_Om said, that's fine.
In situations where Build Configurations are not sufficient, you might take a look at this...
