mkx
Device configuration tool not working in STM32CubeIDE v2.0.0
I've done a fresh install of STM32CubeIDE on my Win11 computer. (Version: 2.0.0 Build: 26820_20251114_1348 UTC). I installed CubeMX through Help > Install New Software and then tried to open an existing projects .ioc file. This did not work, I got the following error (log also attached)
The ioc file itself is fine. I can open it on other computers without a problem.
I tried installing CubeMX as a seperate program, which works fine. I assume its the CubeIDE plugin that has a problem
Souhaib MAZHOUDBest answer
Hello @mkx
As you can see here, CubeMX plug-in has been removed from the STM32CubeIDE.
BR, Souhaib
To give better visibility on the answered topics, please click on 'Best answer' on the reply which solved your issue or answered your question.
Hello @mkx
BR, Souhaib
mkx
mkxAuthor
Oh, I wasn't aware of that. Thanks for the quick answer.
Might be an idea to show this in the IDE in a a more user-friendly way. I was able to find and install the CubeMX plugin just fine, so it wasnt clear to me that this was a removed feature.
Andrew Neil
CubeIDE no longer integrates the MX functionality - it's now only available in the separate, standalone application:
https://community.st.com/t5/stm32cubeide-mcus/cubeide-2-0-does-not-open-ioc-files/m-p/857301/highlight/true#M39483
https://community.st.com/t5/stm32cubeide-mcus/how-to-enter-pinout-view/m-p/859592/highlight/true#M39708
PS:
See this post (by @TDK ) on how to start an external editor from within the IDE.
