Defines not changing grayed out statuses
Using STM32CubeIDE 1.15.1.  Running LwIP_Server_socket_RTOS on a Nucleo-H723ZG board.
When I change #define LWIP_DHCP to zero my DHCP stuff is not grayed out.  It definitely starts using static IP, I'm able to connect and see the web pages.  I'm used to IDE's responding to #define changes, should I not expect this with CubeIDE?
    Andrew Neil
    Andrew NeilBest answer
    Do you have the option enabled?
    Do you see shading elsewhere?
    You may need to rebuild the editor's index:
    https://community.st.com/t5/stm32-mcus-boards-and-hardware/discrepancy-between-the-code-in-editor-and-the-build-process/m-p/681942/highlight/true#M19299
    Andrew Neil
    st3ph3nAuthor
    Yes!  Exactly the solution... thank you very much.  I guess I'm used to this happening with each clean/build cycle.  Is this something that can be automated, or included in the clean/build?  Just curious why this stuff is not done automatically.  Thanks again for your help.
    Andrew Neil
    It should just happen "on-the-fly", but sometimes it gets "stuck" and needs a manual rebuild/refresh.
    Hopefully, having done that, it will now work ... ?
