Nick Faughey
Debugging X-CUBE-AWS issues on STM32CubeIDE
I'm trying to debug the default X-CUBE-AWS application on the B-L4S5I-IOT01 dev board, but when I launch the debug configuration in STM32CubeIDE, I get the following error:
Break at address "0x80209d8" with no debug information available, or outside of program code.
I'm guessing it's halted at the main() breakpoint, but for some reason STM32CubeIDE doesn't know what's there. The ELF seems to be starting from 0x0800000 like it should, after the bigelftuner.exe post-build step.
