RGhos.1
Sep 13, 2022 7:01 AM UTC
Debugger Message G491
since the G491 was the last awailable chip to buy we built a board containing that µC.
We use KEIL IDE usually but STMCubeIDE shows a similar message when trying to debug the program:
"Break at address "0x1fff4e48" with no debug information available, or outside of program code."
In both IDEs the debugger doesn't work.
Can anybody helb me?
Is more information necessary?
Sincerely, Rahul
Sep 13, 2022 9:41 AM UTC
Hello @Community member​ and welcome to the Community :)
Check the optional bytes, and BOOT0 pin.
The option can be found in STM32CubeProgrammer -> Option bytes -> User Configuration
Check also in the AN2606, bootloader activation pattern for for STM32G491.
Imen
Sep 13, 2022 12:47 PM UTC
Check if BOOT0 is pulled low.
RGhos.1
RGhos.1Author
Sep 13, 2022 10:45 AM UTC
0693W00000SvFtCQAV.jpgHello Imen,
thank you for your reply.
We use PB8/BOOT0 as I²C-SCL - so there is an pull-up of 4k7 ohms connected.
The AN I will at later.
Rahul
