debugger breaks/crashes when setting a variable in live expressions window (Segger JLINK)
Hi
I have a global variable in the CUBE IDE's LIVE EXPRESSIONS window, I can see the values of my variablechaning. The values make sense. When I change the value manually, either the execution stops, the value is changed and I have to click on RESUME/F8 to continue debugging or the debugger detaches from target.
Is this a known issue?
I am using Segger Jlink via Jtag and/or SWD
