Senior III
Apr 9, 2025 2:58 PM UTC
Debug - watch variable error
I'm trying to debug my UART debug code. I suspect that I have calculated the Baud rate incorrectly.
I run the code in debug & I'm trying to view the value in `what_baud` but the debugger isn't having it, see below.
How do I do this correctly?
NicRobertsBest answer
Senior III
Apr 10, 2025 1:44 PM UTC
It was a context issue, I can see it when I'm stepping through the function where it exists.
Andrew Neil
Apr 9, 2025 3:10 PM UTC
Probably your what_baud variable has been optimised-out - hence:
You could try making it volatile
Or just watch the whole expression.
NicRobertsAuthorBest answer
Senior III
Andrew Neil
Apr 10, 2025 1:46 PM UTC
Of course - the whole point of local variables is that they do not exist outside their function!
