AKoek.1
Debug bootloader and application
I am trying to create a custom bootloader and having trouble debugging where in the application it jumps to.
Both projects are in the IDE.
If needed. The MCU I use is a STM32F103RET6
Piranha
Principal III
February 19, 2020
Better do it with a much simpler and better approach compared to a typical one from ST's examples. Look for my comment here:
https://community.st.com/s/question/0D50X0000AFpTmUSQV/using-nvicsystemreset-in-bootloaderapplication-jumps
AKoek.1
AKoek.1Author
I have seen the example but I cannot figure out how to implement it myself.
My experience with assembly is none
February 20, 2020
Not using CubeIDE here, but should be able to at least step across the transition in a disassembly view. Make sure it is getting to the right place. Use the .MAP file from the linker to understand where Reset_Handler, main, etc are situated in the application image.
Perhaps look at IAP (In-App Programming) examples.
If the clocks and PLL are already up, I would not perform that step again. Make sure the vector table is set in SCB->VTOR correctly, check SystemInit(). Ideally have a UART working so you can output some telemetry as you leave loader and enter application.
Might want to get a better understanding of how the MCUs work, it will help with the implementational detail, and following what's happening.
