CubeIDE ST account login certificate error on docker (proxy & internet work)
Hello I manage to install cube ide on Ubuntu 24.04 custom docker.
The internet connection works as i properly configured the proxy and install my certificates on the system, and on the java side (jre/bin/keytool) of eclipse based Cube ide.
The check connection works in 'windows > preferences > STM32Cube > Firmware updater' menu (see attached image) and I am able to download and install some of the updates via 'help > check for update menu'
The compilation of my project works and also able to debug and program via st link from the docker.
Nevertheles I still encounter a problem when i tried to connect to my st account, via 'Help > STM32Cube updates > Connection to St' i have a first page where i can click on 'Enter myST account information', then it the open a second page based on a web browser (see attahed image) where it states that
This site can’t be reached
The webpage at https://sso.st.com/as/authorization.oauth2?client_id=oidc_prod_stm32cube-ua-cubemx1&scope=openid&response_type=code&redirect_uri=https%3A%2F%2Fstm32cube-ua.st.com%2Fapi%2Fuser_service%2Flogin%2Fcallback&response_mode=query might be temporarily down or it may have moved permanently to a new web address.
ERR_CERT_AUTHORITY_INVALID
It seems this use chromium underneath but does not use system certifcates, see the workspace_1.18.0/.metadata/.ide.log below
2025-05-21 10:22:27,067 [INFO] Activator:177 - !SESSION log4j initialized
2025-05-21 10:22:31,067 [INFO] LogOutputStream:77 - [STDOUT_REDIRECT]
2025-05-21 10:22:33,418 [INFO] ApplicationProperties:184 - Using Application install path: /opt/st/stm32cubeide_1.18.0/../../../home/neiluj/.eclipse/com.st.stm32cube.ide.mcu.rcp.product_1.18.0_139067096_linux_gtk_x86_64/plugins/com.st.stm32cube.common.mx_6.14.1.202504091515
2025-05-21 10:22:33,441 [INFO] DbMcusXml:78 - Set database path to: /opt/st/stm32cubeide_1.18.0/../../../home/neiluj/.eclipse/com.st.stm32cube.ide.mcu.rcp.product_1.18.0_139067096_linux_gtk_x86_64/plugins/com.st.stm32cube.common.mx_6.14.1.202504091515//db//mcu/
2025-05-21 10:22:33,442 [INFO] ApiDb:274 - Set plugin database path to: /opt/st/stm32cubeide_1.18.0/../../../home/neiluj/.eclipse/com.st.stm32cube.ide.mcu.rcp.product_1.18.0_139067096_linux_gtk_x86_64/plugins/com.st.stm32cube.common.mx_6.14.1.202504091515//db//plugins/boardmanager/
2025-05-21 10:22:33,442 [WARN] ApiDb:259 - Overriding images path with different value: => /opt/st/stm32cubeide_1.18.0/../../../home/neiluj/.eclipse/com.st.stm32cube.ide.mcu.rcp.product_1.18.0_139067096_linux_gtk_x86_64/plugins/com.st.stm32cube.common.mx_6.14.1.202504091515//db//plugins/mcufinder/images/
2025-05-21 10:22:33,452 [INFO] ApiDb:250 - Set database path to: /home/neiluj/.stmcufinder/plugins/mcufinder//mcu/
2025-05-21 10:22:33,455 [INFO] DbMcusAds:125 - Set database path to: /home/neiluj/.stmcufinder/plugins/mcufinder//mcu/
2025-05-21 10:22:33,458 [INFO] CrossReferenceDbSqlite:203 - Set database path to: /home/neiluj/.stmcufinder/plugins/mcufinder//mcu/cs/
2025-05-21 10:22:33,599 [INFO] RulesReader:64 - Compatibility file has been processed (302 Rules)
2025-05-21 10:22:33,674 [INFO] DbMcusXml:78 - Set database path to: /opt/st/stm32cubeide_1.18.0/../../../home/neiluj/.eclipse/com.st.stm32cube.ide.mcu.rcp.product_1.18.0_139067096_linux_gtk_x86_64/plugins/com.st.stm32cube.common.mx_6.14.1.202504091515//db//mcu/
2025-05-21 10:22:33,674 [INFO] ApiDb:274 - Set plugin database path to: /opt/st/stm32cubeide_1.18.0/../../../home/neiluj/.eclipse/com.st.stm32cube.ide.mcu.rcp.product_1.18.0_139067096_linux_gtk_x86_64/plugins/com.st.stm32cube.common.mx_6.14.1.202504091515//db//plugins/boardmanager/
2025-05-21 10:22:33,674 [INFO] ApiDb:261 - Set plugin images path to: /opt/st/stm32cubeide_1.18.0/../../../home/neiluj/.eclipse/com.st.stm32cube.ide.mcu.rcp.product_1.18.0_139067096_linux_gtk_x86_64/plugins/com.st.stm32cube.common.mx_6.14.1.202504091515//db//plugins/mcufinder/images/
2025-05-21 10:22:33,675 [WARN] DbFile:41 - Overriding database path with different value: /home/neiluj/.stmcufinder/plugins/mcufinder/ => /home/neiluj/.stmcufinder/plugins/mcufinder
2025-05-21 10:22:33,675 [INFO] ApiDb:250 - Set database path to: /home/neiluj/.stmcufinder/plugins/mcufinder//mcu/
2025-05-21 10:22:33,675 [INFO] DbMcusAds:125 - Set database path to: /home/neiluj/.stmcufinder/plugins/mcufinder//mcu/
2025-05-21 10:22:33,675 [INFO] CrossReferenceDbSqlite:203 - Set database path to: /home/neiluj/.stmcufinder/plugins/mcufinder//mcu/cs/
2025-05-21 10:22:33,776 [INFO] MainPanel:272 - HeapMemory: 268435456
2025-05-21 10:22:33,946 [INFO] DbMcusXml:78 - Set database path to: /opt/st/stm32cubeide_1.18.0/../../../home/neiluj/.eclipse/com.st.stm32cube.ide.mcu.rcp.product_1.18.0_139067096_linux_gtk_x86_64/plugins/com.st.stm32cube.common.mx_6.14.1.202504091515//db//mcu/
2025-05-21 10:22:33,947 [INFO] ApiDb:274 - Set plugin database path to: /opt/st/stm32cubeide_1.18.0/../../../home/neiluj/.eclipse/com.st.stm32cube.ide.mcu.rcp.product_1.18.0_139067096_linux_gtk_x86_64/plugins/com.st.stm32cube.common.mx_6.14.1.202504091515//db//plugins/boardmanager/
2025-05-21 10:22:33,947 [INFO] ApiDb:261 - Set plugin images path to: /opt/st/stm32cubeide_1.18.0/../../../home/neiluj/.eclipse/com.st.stm32cube.ide.mcu.rcp.product_1.18.0_139067096_linux_gtk_x86_64/plugins/com.st.stm32cube.common.mx_6.14.1.202504091515//db//plugins/mcufinder/images/
2025-05-21 10:22:33,947 [WARN] DbFile:41 - Overriding database path with different value: /home/neiluj/.stmcufinder/plugins/mcufinder/ => /home/neiluj/.stmcufinder/plugins/mcufinder
2025-05-21 10:22:33,948 [INFO] ApiDb:250 - Set database path to: /home/neiluj/.stmcufinder/plugins/mcufinder//mcu/
2025-05-21 10:22:33,948 [WARN] DbFile:41 - Overriding database path with different value: /home/neiluj/.stmcufinder/plugins/mcufinder/ => /home/neiluj/.stmcufinder/plugins/mcufinder
2025-05-21 10:22:33,948 [INFO] DbMcusAds:125 - Set database path to: /home/neiluj/.stmcufinder/plugins/mcufinder//mcu/
2025-05-21 10:22:33,949 [INFO] CrossReferenceDbSqlite:203 - Set database path to: /home/neiluj/.stmcufinder/plugins/mcufinder//mcu/cs/
2025-05-21 10:22:33,970 [INFO] ApplicationProperties:184 - Using Application install path: /opt/st/stm32cubeide_1.18.0/../../../home/neiluj/.eclipse/com.st.stm32cube.ide.mcu.rcp.product_1.18.0_139067096_linux_gtk_x86_64/plugins/com.st.stm32cube.common.mx_6.14.1.202504091515
2025-05-21 10:22:33,972 [INFO] PluginManage:196 - Search for loadable plugins [exclusion list=, ]
2025-05-21 10:22:33,973 [INFO] PluginManage:310 - Check plugin analytics
2025-05-21 10:22:34,167 [INFO] AnalyticsPlugin:253 - Accepted Software Licenses:
2025-05-21 10:22:34,167 [INFO] AnalyticsPlugin:255 - Accepted CMSIS Pack Licenses:
2025-05-21 10:22:34,168 [INFO] AnalyticsPlugin:257 - Accepted Firmware Licenses:
2025-05-21 10:22:34,170 [INFO] PluginManage:359 - Loaded plugin analytics (category:tool,tabindex:-1)
2025-05-21 10:22:34,171 [INFO] PluginManage:310 - Check plugin cadmodel
2025-05-21 10:22:34,177 [INFO] CADModel:105 - Init CAD model plugin
2025-05-21 10:22:34,177 [INFO] PluginManage:359 - Loaded plugin cadmodel (category:power,tabindex:5)
2025-05-21 10:22:34,177 [INFO] PluginManage:310 - Check plugin clock
2025-05-21 10:22:34,190 [INFO] PluginManage:359 - Loaded plugin clock (category:base,tabindex:2)
2025-05-21 10:22:34,190 [INFO] PluginManage:310 - Check plugin ddr
2025-05-21 10:22:34,194 [INFO] PluginManage:359 - Loaded plugin ddr (category:tool,tabindex:6)
2025-05-21 10:22:34,195 [INFO] PluginManage:310 - Check plugin filemanager
2025-05-21 10:22:34,419 [INFO] PluginManage:359 - Loaded plugin filemanager (category:base,tabindex:10)
2025-05-21 10:22:34,420 [INFO] PluginManage:310 - Check plugin ipmanager
2025-05-21 10:22:34,427 [INFO] PluginManage:359 - Loaded plugin ipmanager (category:base,tabindex:5)
2025-05-21 10:22:34,427 [INFO] PluginManage:310 - Check plugin lpbam
2025-05-21 10:22:34,439 [INFO] PluginManage:359 - Loaded plugin lpbam (category:base,tabindex:0)
2025-05-21 10:22:34,439 [INFO] PluginManage:310 - Check plugin memorymap
2025-05-21 10:22:34,458 [INFO] PluginManage:359 - Loaded plugin memorymap (category:base,tabindex:4)
2025-05-21 10:22:34,458 [INFO] PluginManage:310 - Check plugin pinoutandconfiguration
2025-05-21 10:22:34,473 [INFO] PluginManage:359 - Loaded plugin pinoutandconfiguration (category:base,tabindex:1)
2025-05-21 10:22:34,474 [INFO] PluginManage:310 - Check plugin pinoutconfig
2025-05-21 10:22:34,571 [WARN] SupportedApi:132 - Cannot load RTOS API schema: s4s-elt-must-match.1: The content of 'definitions' must match (annotation?, (simpleType | complexType)?, (unique | key | keyref)*)). A problem was found starting at: attribute.
2025-05-21 10:22:34,730 [INFO] PluginManage:359 - Loaded plugin pinoutconfig (category:base,tabindex:0)
2025-05-21 10:22:34,731 [INFO] PluginManage:310 - Check plugin power
2025-05-21 10:22:34,745 [INFO] PluginManage:359 - Loaded plugin power (category:power,tabindex:4)
2025-05-21 10:22:34,745 [INFO] PluginManage:310 - Check plugin projectmanager
2025-05-21 10:22:34,761 [INFO] PluginManage:359 - Loaded plugin projectmanager (category:projectmanager,tabindex:4)
2025-05-21 10:22:34,761 [INFO] PluginManage:310 - Check plugin rif
2025-05-21 10:22:34,773 [INFO] PluginManage:359 - Loaded plugin rif (category:base,tabindex:3)
2025-05-21 10:22:34,773 [INFO] PluginManage:310 - Check plugin thirdparty
2025-05-21 10:22:34,955 [WARN] IntegrityCheckThread:84 - waiting for thirdparty lock release [integrity check]
2025-05-21 10:22:34,956 [INFO] PluginManage:359 - Loaded plugin thirdparty (category:base,tabindex:-1)
2025-05-21 10:22:34,956 [INFO] PluginManage:310 - Check plugin tools
2025-05-21 10:22:34,956 [INFO] IntegrityCheckThread:86 - entering critical section [integrity check]
2025-05-21 10:22:34,957 [INFO] ThirdPartyUpdaterWithRetryManager:70 - Updater plugin not ready yet. [1/15]
2025-05-21 10:22:34,959 [INFO] PluginManage:359 - Loaded plugin tools (category:base,tabindex:7)
2025-05-21 10:22:34,959 [INFO] PluginManage:310 - Check plugin tutovideos
2025-05-21 10:22:35,150 [INFO] PluginManage:359 - Loaded plugin tutovideos (category:base,tabindex:-1)
2025-05-21 10:22:35,150 [INFO] PluginManage:310 - Check plugin updater
2025-05-21 10:22:35,173 [INFO] PluginManage:359 - Loaded plugin updater (category:base,tabindex:12)
2025-05-21 10:22:35,173 [INFO] PluginManage:310 - Check plugin userauth
2025-05-21 10:22:35,178 [INFO] UserAuth:118 - Init User Auth plugin
2025-05-21 10:22:35,179 [INFO] PluginManage:359 - Loaded plugin userauth (category:base,tabindex:14)
2025-05-21 10:22:35,179 [INFO] PluginManage:283 - PluginManage : Loaded plugins [18]
2025-05-21 10:22:35,340 [INFO] PinOutPanel:1589 - setPackage(No Configuration,No Configuration)
2025-05-21 10:22:35,403 [INFO] CADModel:165 - CPN selected for project level
2025-05-21 10:22:35,404 [INFO] CADModel:114 - Register for checkConnection events
2025-05-21 10:22:35,418 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,419 [INFO] PluginManager:220 - loadIPPluginJar : add freertos
2025-05-21 10:22:35,425 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,426 [INFO] PluginManager:220 - loadIPPluginJar : add touchsensing
2025-05-21 10:22:35,429 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,429 [INFO] PluginManager:220 - loadIPPluginJar : add extmemmanager
2025-05-21 10:22:35,431 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,431 [INFO] PluginManager:220 - loadIPPluginJar : add ts
2025-05-21 10:22:35,434 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,434 [INFO] PluginManager:220 - loadIPPluginJar : add tracer_emb
2025-05-21 10:22:35,435 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,435 [INFO] PluginManager:220 - loadIPPluginJar : add quadspi
2025-05-21 10:22:35,438 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,438 [INFO] PluginManager:220 - loadIPPluginJar : add i3c
2025-05-21 10:22:35,441 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,441 [INFO] PluginManager:220 - loadIPPluginJar : add can
2025-05-21 10:22:35,444 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,445 [INFO] PluginManager:220 - loadIPPluginJar : add usart
2025-05-21 10:22:35,447 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,447 [INFO] PluginManager:220 - loadIPPluginJar : add cryp
2025-05-21 10:22:35,453 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,453 [INFO] PluginManager:220 - loadIPPluginJar : add resmgrutility
2025-05-21 10:22:35,455 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,455 [INFO] PluginManager:220 - loadIPPluginJar : add tim
2025-05-21 10:22:35,456 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,457 [INFO] PluginManager:220 - loadIPPluginJar : add comp
2025-05-21 10:22:35,459 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,459 [INFO] PluginManager:220 - loadIPPluginJar : add opamp
2025-05-21 10:22:35,465 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,466 [INFO] PluginManager:220 - loadIPPluginJar : add mdma
2025-05-21 10:22:35,468 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,468 [INFO] PluginManager:220 - loadIPPluginJar : add genericplugin
2025-05-21 10:22:35,470 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,470 [INFO] PluginManager:220 - loadIPPluginJar : add tsc
2025-05-21 10:22:35,472 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,474 [INFO] PluginManager:220 - loadIPPluginJar : add radio
2025-05-21 10:22:35,477 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,477 [INFO] PluginManager:220 - loadIPPluginJar : add sai
2025-05-21 10:22:35,480 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,480 [INFO] PluginManager:220 - loadIPPluginJar : add gtzc
2025-05-21 10:22:35,488 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,488 [INFO] PluginManager:220 - loadIPPluginJar : add adc
2025-05-21 10:22:35,491 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,491 [INFO] PluginManager:220 - loadIPPluginJar : add openamp
2025-05-21 10:22:35,496 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,497 [INFO] PluginManager:220 - loadIPPluginJar : add gpio
2025-05-21 10:22:35,500 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,501 [INFO] PluginManager:220 - loadIPPluginJar : add lorawan
2025-05-21 10:22:35,507 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,507 [INFO] PluginManager:220 - loadIPPluginJar : add dma
2025-05-21 10:22:35,509 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,509 [INFO] PluginManager:220 - loadIPPluginJar : add fatfs
2025-05-21 10:22:35,513 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,513 [INFO] PluginManager:220 - loadIPPluginJar : add pdm2pcm
2025-05-21 10:22:35,520 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,520 [INFO] PluginManager:220 - loadIPPluginJar : add linkedlist
2025-05-21 10:22:35,522 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,522 [INFO] PluginManager:220 - loadIPPluginJar : add gfxmmu
2025-05-21 10:22:35,531 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,533 [INFO] PluginManager:220 - loadIPPluginJar : add plateformsettings
2025-05-21 10:22:35,536 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,536 [INFO] PluginManager:220 - loadIPPluginJar : add hash
2025-05-21 10:22:35,541 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,541 [INFO] PluginManager:220 - loadIPPluginJar : add fmc
2025-05-21 10:22:35,544 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,544 [INFO] PluginManager:220 - loadIPPluginJar : add dfsdm
2025-05-21 10:22:35,547 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,548 [INFO] PluginManager:220 - loadIPPluginJar : add ddr_ctrl_phy
2025-05-21 10:22:35,553 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,553 [INFO] PluginManager:220 - loadIPPluginJar : add stm32_wpan
2025-05-21 10:22:35,555 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,555 [INFO] PluginManager:220 - loadIPPluginJar : add aes
2025-05-21 10:22:35,556 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,556 [INFO] PluginManager:220 - loadIPPluginJar : add ltdc
2025-05-21 10:22:35,561 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,561 [INFO] PluginManager:220 - loadIPPluginJar : add usbx
2025-05-21 10:22:35,563 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,563 [INFO] PluginManager:220 - loadIPPluginJar : add ucpd
2025-05-21 10:22:35,566 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,566 [INFO] PluginManager:220 - loadIPPluginJar : add i2c
2025-05-21 10:22:35,569 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,569 [INFO] PluginManager:220 - loadIPPluginJar : add dma3
2025-05-21 10:22:35,572 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,573 [INFO] PluginManager:220 - loadIPPluginJar : add ipddr
2025-05-21 10:22:35,575 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,576 [INFO] PluginManager:220 - loadIPPluginJar : add spi
2025-05-21 10:22:35,579 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,579 [INFO] PluginManager:220 - loadIPPluginJar : add i2s
2025-05-21 10:22:35,587 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,587 [INFO] PluginManager:220 - loadIPPluginJar : add gic
2025-05-21 10:22:35,592 [INFO] IPUIPlugin:80 - create IPUIPlugin
2025-05-21 10:22:35,593 [INFO] PluginManager:220 - loadIPPluginJar : add nvic
2025-05-21 10:22:35,697 [FATAL] Updater:351 - Updater called before beeing initialized
2025-05-21 10:22:35,729 [INFO] RulesReader:64 - Compatibility file has been processed (302 Rules)
2025-05-21 10:22:35,738 [INFO] RulesReader:64 - Compatibility file has been processed (302 Rules)
2025-05-21 10:22:35,744 [INFO] CADModel:165 - CPN selected for project level
2025-05-21 10:22:35,744 [INFO] CADModel:114 - Register for checkConnection events
2025-05-21 10:22:35,744 [FATAL] Updater:351 - Updater called before beeing initialized
2025-05-21 10:22:35,744 [ERROR] CADModel:125 - Updater not yet initialized, retry later
2025-05-21 10:22:35,862 [FATAL] Updater:351 - Updater called before beeing initialized
2025-05-21 10:22:35,864 [INFO] CADModel:165 - CPN selected for project level
2025-05-21 10:22:35,864 [INFO] CADModel:114 - Register for checkConnection events
2025-05-21 10:22:35,864 [FATAL] Updater:351 - Updater called before beeing initialized
2025-05-21 10:22:35,864 [ERROR] CADModel:125 - Updater not yet initialized, retry later
2025-05-21 10:22:35,868 [FATAL] Updater:351 - Updater called before beeing initialized
2025-05-21 10:22:35,947 [FATAL] Updater:351 - Updater called before beeing initialized
2025-05-21 10:22:35,952 [INFO] DbMcusAds:53 - JSON generation date=Thu Sep 30 08:55:09 CEST 2021 (1632984909247)
2025-05-21 10:22:35,952 [FATAL] Updater:351 - Updater called before beeing initialized
2025-05-21 10:22:35,984 [WARN] DetailPanel:346 - Failed to get advertising image, set to default
2025-05-21 10:22:36,196 [FATAL] Updater:351 - Updater called before beeing initialized
2025-05-21 10:22:36,199 [FATAL] Updater:351 - Updater called before beeing initialized
2025-05-21 10:22:36,200 [WARN] DetailPanel:346 - Failed to get advertising image, set to default
2025-05-21 10:22:36,200 [FATAL] Updater:351 - Updater called before beeing initialized
2025-05-21 10:22:36,227 [ERROR] Updater:1198 - MainUpdater not yet initialized. External WinMGr cannot be set.
2025-05-21 10:22:36,230 [INFO] Updater:1134 - Updater Version found : 6.14.1
2025-05-21 10:22:36,257 [INFO] ApplicationProperties:184 - Using Application install path: /opt/st/stm32cubeide_1.18.0/../../../home/neiluj/.eclipse/com.st.stm32cube.ide.mcu.rcp.product_1.18.0_139067096_linux_gtk_x86_64/plugins/com.st.stm32cube.common.mx_6.14.1.202504091515
2025-05-21 10:22:36,664 [INFO] MainUpdater:2872 - connection check result : 10
2025-05-21 10:22:36,665 [INFO] MainUpdater:289 - Updater Check For Update Now.
2025-05-21 10:22:36,665 [INFO] MicroXplorer:498 - Change Database Version : DB.6.0.141
2025-05-21 10:22:36,671 [INFO] McuFinderGlobals:63 - Set McuFinder mode to 2 (CubeIDE integrated)
2025-05-21 10:22:36,671 [INFO] UserAuth:171 - activating auth plugin
2025-05-21 10:22:36,673 [INFO] UserAuth:484 - Internet connection configuration mode: 1
2025-05-21 10:22:36,702 [INFO] JxBrowserEngine:152 - Initiate JxBrowser Engine with user profile folder
2025-05-21 10:22:36,837 [INFO] CheckServerUpdateThread:120 - End of CheckServer Thread
2025-05-21 10:22:37,282 [INFO] WebApp:169 - Instantiating new browser for Auth
2025-05-21 10:22:37,975 [INFO] WebApp:463 - Apply proxy settings
2025-05-21 10:22:37,975 [INFO] WebApp:548 - Chromium requires no authentication
2025-05-21 10:22:37,985 [INFO] WebApp:491 - Direct internet connection detected
2025-05-21 10:22:38,040 [INFO] WebApp:894 - Register for checkConnection events
2025-05-21 10:22:38,041 [INFO] WebApp:463 - Apply proxy settings
2025-05-21 10:22:38,041 [INFO] WebApp:548 - Chromium requires no authentication
2025-05-21 10:22:38,042 [INFO] WebApp:491 - Direct internet connection detected
2025-05-21 10:22:38,121 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.FP-SNS-MOTENVWB1.1.4.0
2025-05-21 10:22:38,131 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.X-CUBE-AI.10.0.0
2025-05-21 10:22:38,136 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.FP-SNS-SMARTAG2.1.2.0
2025-05-21 10:22:38,141 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.FP-SNS-MOTENV1.5.0.0
2025-05-21 10:22:38,146 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.FP-ATR-SIGFOX1.3.2.0
2025-05-21 10:22:38,154 [WARN] PackLoader:240 - Cannot read IP mode file for STMicroelectronics.FP-SNS-STBOX1.2.0.0
2025-05-21 10:22:38,157 [INFO] ThirdParty:978 - Integrity check success = true
2025-05-21 10:22:38,158 [INFO] IntegrityCheckThread:100 - exiting critical section [integrity check]
2025-05-21 10:22:38,158 [INFO] IntegrityCheckThread:103 - End integrity checks thread
2025-05-21 10:22:38,236 [INFO] WebApp:191 - Connection restablished
2025-05-21 10:22:38,250 [INFO] WebApp:225 - Starting web application
2025-05-21 10:22:38,250 [INFO] WebApp:593 - Web application path used /opt/st/stm32cubeide_1.18.0/../../../home/neiluj/.eclipse/com.st.stm32cube.ide.mcu.rcp.product_1.18.0_139067096_linux_gtk_x86_64/plugins/com.st.stm32cube.common.mx_6.14.1.202504091515/db/plugins/mcufinder/reactClient1/index.html
2025-05-21 10:23:55,460 [INFO] McuFinderGlobals:63 - Set McuFinder mode to 2 (CubeIDE integrated)
2025-05-21 10:23:55,461 [INFO] UserAuth:171 - activating auth plugin
2025-05-21 10:23:55,466 [INFO] UserAuth:484 - Internet connection configuration mode: 1
Is there a way to configure properly the certifcates to be able to connect to my account?
DDrin.1
Same issue here. I came to the same conclusion that it's the Chromium being used under-the-hood, which is neither honoring the system CA certificate store, nor the JRE's.
Chromium seems a common enough tool, that finding a way to import a CA cert into it seems like it would be easy to find. No luck yet for me, though.
I got it working by importing CA certificates to ~/.pki/nssdb/ with certutil:
$ sudo apt install libnss3-tools
$ certutil -d ~/.pki/nssdb/ -A -t "C,," -n <NAME> -i /usr/local/share/ca-certificates/<NAME>.crt
Edit for future reference:
This step is in addition to adding the certificates to the installation's JRE keystore as described in
https://community.st.com/t5/stm32-mcus/how-to-import-private-ca-certificates-into-jre-truststore-when/ta-p/49523
$ cd /opt/st/stm32cubeide_1.19.0/plugins/com.st.stm32cube.ide.jre.linux64_3.4.0.202409160955/jre
$ sudo bin/keytool -importcert -alias <NAME> -keystore lib/security/cacerts -file /usr/local/share/ca-certificates/<NAME>.crt
