CubeIDE not switching context properly from CubeMX to C editor tab
- 3 replies
- 1363 views
Hi, I've noticed for the past few versions that this issue has been present. When I switch from a C editor tab to the CubeMX (.ioc file) tab the view transitions properly but when I switch back the other direction, it changes tab to the C file and changes the context then quickly changes the tab back to the .ioc file.
I recorded a screen capture of it which I have attached so you can see what I mean.
Is this a known bug, is there something I can do to fix it? Will it be fixed in a future release?
