Andrew Neil
CubeIDE: debug multiple instances of a project?
  • March 29, 2021
  • 9 replies
  • 2696 views
either to debug multiple instances of the same project; eg, two BLE peripherals
or to debug multiple projects; eg, a BLE Central and a BLE peripheral.
In the latter case, I guess you could put each one in a separate Workspace - but that doesn't help in the former case.
This can't , surely, be an uncommon situation?
Andrew Neil
Hmmm ... even with separate Workspaces, it doesn't work:
this is on a B-L072Z-LRWAN1 with the on-board ST-Link converted to a J-Link
https://www.segger.com/products/debug-probes/j-link/models/other-j-links/st-link-on-board/
Is this just a "feature" of the J-Link conversion, or would the original ST-Link be just the same?
Ozone
Principal
March 30, 2021
I think you would need separate GDB server instances for each debug instance, with different port settings.
Andrew Neil
How would you do that?
Radosław
Just change telnet port for one of projects, and set proper SN for debug probe.
Andrew Neil
Yes - SN set already.
Where does the port need changing - just in the Project? also for the J-Link?
Is there a recommended "secondary" port number?
Note that this "just works" with 2 instances of Segger Ozone - apart from specifying SN, nothing else needs fiddling with.
And it still leaves the question of how to debug 2 instances of the same project
Radosław
Same project? it will be very hard to manage, source code will be shared, the best way will be a copy of this project, and two instances od CubeIde.
Andrew Neil
Of course the source code would be shared - that's the whole point.
Andrew Neil
