CubeIDE 2.0.0 - "Could not create GBM EGL display: EGL_NOT_INITIALIZED. Aborting..."
I just installed CubeIDE 2.0.0 on Ubuntu 24.04 (finally!).  However I cannot launch it (I do get the initial workspace selection popup, but after selecting "Launch" I get this error):
$ /opt/st/stm32cubeide_2.0.0/stm32cubeide_wayland
A little bit of poking around on Google suggests that installing libnvidia-egl-wayland1 should fix this issue, however on my system libnvidia-egl-wayland1 is already installed:
$ dpkg -l | grep libnvidia-egl-wayland1
ii libnvidia-egl-wayland1:amd64 1:1.1.13-1ubuntu0.1 amd64 Wayland EGL External Platform library -- shared library
ii libnvidia-egl-wayland1:i386 1:1.1.13-1ubuntu0.1 i386 Wayland EGL External Platform library -- shared library
I have tried rebooting a couple of times but I keep getting the same error.  Does anyone know how to fix this?
Ghofrane GSOURI
Hello @dsorber
I'm currently checking this behavior. I will get back to you asap.
THX
Ghofrane
dsorberAuthor
Thanks. I should also mention that I tried the other version (without the "_wayland") and I get the same error:
Ghofrane GSOURI
Hello @dsorber
Could you please share your workspace log located at ~/.stm32cubeide_2.0.0/.metadata/.log?
dsorberAuthor
Any updates on this issue?
dsorberAuthor
Ghofrane GSOURI
Hello @dsorber
Sorry for the late reply.
Could you please confirm exactly which STM32CubeIDE installer you downloaded and used ?
In addition, could you try installing STM32CubeIDE under /home/st instead of /opt/st and let me know if the issue persists?
THX
Ghofrane
