cube IDE flipping out
This IDE has gone into some crazy mode where each window maximizes itself on the screen/. I've tried clicking every single maximize/minimize/restore button, closeing the app, restarting the computer.....
This worked and suddenly broke.
Is there some way to make this thing reset back to it's default state?
Another screen
CTapp.1
Senior III
Have you tried resetting the perspective (Menu item - Window / Perspective / Reset Perspective...)?
All posts are made in a personal capacity. MISRA C++ Chair, MISRA C WG Member, Director The MISRA Consortium Limited (TMCL)
This did it, thanks
Ghofrane GSOURI
Hello @sgordon777
First let me thank you for posting.
Could you please provide more details about the STM32CubeIDE version that you are using and your OS.
As mentioned by @CTapp.1 :Go to Window in the menu bar. Select Reset Perspective. This will reset the layout to its default configuration and if the issue persists try switching to a new workspace: Go to File > Switch Workspace > Other...
THX
Ghofrane
AScha.3
Double clicking in free area on top of window doesnt restore it ?
here ->
CTapp.1
Senior III
That's worth a try - it does normally. If it doesn't, it's worth trying to reset the perspective.
No, it didn't for me. Thats the first things I tried since I know that double clicking this border area can decouble windows.
I fixed it with "reset perspective" option above
matte
CTRL+M = Maximizie active View or Editor
The root-cause is as you said probably a double-click on a border area or using CTRL+M.
You can of course do a "perspective reset". But an easier fix (less impact on your perspective tweaks) is to hit CTRL+M again to untoggle maxmimization.
