Cube don't generate code, just pop up window for fraction of second.
It's freshly installed cubeide precisely. Version: 1.15.1 i created a project on stm32u545ret6q mcu. When i set up cubemx just for simple test/generate of code a small window pops up for a fraction of a second, and code is not generated.
This window has written "Progress Information".
I also see one warning: Project "InzStm" has no explicit encoding set.
    Semer CHERNI
    Hello @gurdzinskidawid
    First let me thank you for posting.
    I made the test with the attached ioc and I was able to generate code.
    Could you please share the STM32CubeMX.log file found under /user/.stm32cubemx folder.
    Or run CubeMX with the command line and share the content of the console.
    KR,
    Semer.
