Couldnot reconstruct chunks at receiver end
Hello!
I am doing a project using STM32cube ide , the problem I am facing is at the receiver end when the data at the transmitter is transmitted in form of chunks but at the receiver end, the received data could not reconstruct , the receiver is taking 4 sec to switch and send acknowledgement that the packet is received successfully. Can Someone suggest what should I do further to achieve the data reconstruction and receive acknowledgement.
Andrew Neil
You need to give a lot more detail for anyone to have any idea what you're talking about
@shaik_simran wrote:
at the receiver end .
What "receiver" ?
the data at the transmitter is transmitted in form of chunks .
What "data" ?
What "transmitter" ?
What are these "chunks" ?
at the receiver end, the received data could not reconstruct , .
Why not? Are the "chunks" corrupted, or what?
Is that problem? If it is, then why is it a problem? What does it have to do with the failure to reassemble "chunks"?
Not without a lot more detail from you!
  • What, exactly, are you doing at the moment?
  • What results were you expecting?
  • What results are you actually getting?
  • What investigation/debugging have you done to find the problem(s)?
Andrew Neil
the receiver is taking 4 sec to switch and send acknowledgement that the packet is received successfully. .
Is this related: https://community.st.com/t5/stm32-mcus-wireless/want-to-establish-a-full-duplex-communication-between-two/m-p/677327/highlight/true#M19185 ?
:thinking_face:
