Could not generate the code with STM32cube IDE
Could not generate the code while enter Ctrl+S . Getting the error as in the attached image.
    nkkaderuAuthor
    Using STM32IDE, Stlink Server
    christelle burguera
    Hello nkkaderu,
    Maybe you project is using a software pack you need to download.
    You can check it by opening by doubleclick the ioc file in your project, then check in the Pinout & Configuration view the Middleware and Software Packs you can used for your device.
    If you need to download one, you have to be logged. To do it, please click on myST menu.
    BR
    Explorer
    You need to log into your ST account in cubeide ( in my case I used button near help ). After that ide do what it wants (e.g. updates . etc. ) and generates code
    Explorer II
    Try logging in to my St on the top ribbion
