Copy project doesn't update reference to the .IOC file
When I copy a project within the IDE, it doesn't update the file references and the IOC file doesn't open. Can we have this fixed asap please?
Andrew Neil
welcome to the forum
Please see How to write your question to maximize your chances to find a solution for best results.
In particular, you haven't said what version of CubeIDE you're using.
But, yes - I have seen this issue going back to v1.13.0
As a workaround, you can just rename the .ioc file to have the same name as the project.
PS:
Another thing that never seems to work is the references to Debug Configurations (the .launch files).
I've tried renaming, various ways of exporting & importing, but always end up just having to recreate them from scratch.
sdobbie2Author
I am on version 1.19.0.
It seems to work for now after renaming the IOC,  recompiling and setting up a new run configuration.
