Convert elf file into an srec file
I am using STM32CubeIDE, version 1.2.0.
I want to convert the elf file into an srec file with a particular format.
I have tried editing the command line in the Post-build steps to read:
arm-none-eabi-objcopy.exe -O srec —srec-len=28 —srec-forceS3 “$(BuildArtifactBaseName).elf�? “$(BuildArtifactBaseName).s19�?
A file is generated with the .s19 extension but the file contents are in the Intel hex format.
I have also tried to select the box in Tool Settings/ MCU Post build outputs window labeled “Convert to Motorola S-record�? and I get the same result. The generated file has the .srec extension but the format of the file is Intel hex.
Has anyone figured out the correct way to do this?
