IlConte
Conversion binary with unused byte at 0xFF
There is the possibility to convert in binary mode with unused byte at 0xFF instead 0x00 ?
    June 28, 2023
    There are also tools like srecord if you can pass/control what goes on the command line
    https://srecord.sourceforge.net/
    Don't tend to use, but suspect objcopy has options for empty/slack bytes, and ones own processing tools could also be made aware. On some STM32 parts the erased/blank state is 0x00
